4th GEN COOLANT TANK
Old Aug 23, 2007 | 11:28 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i did a search could not find what i was looking for . does anyone have pics. of what has to be cut out , and procedure for installing . i have a new one ready to install . i just don't want to screw any thing up . thank you .
Old Aug 23, 2007 | 12:00 PM
fenton06's Avatar
Re: 4th GEN COOLANT TANK
I am under the impression it is fairly straightforward what to cut when you have it in your hands...I'll do some digging around and see if I can find an email...
Here is what I found...
Originally Posted by Shr00m
Just cut a hole. You can trace out the shape of the tank and transfer that to the tray. You'll have to cut one of the fender braces as well.
It's a minor one and 1 of 2 down there so no ill effects. The fill
line that goes under the battery will have a rubber line attached that
will reach the stock radiator.
Old Aug 26, 2007 | 06:17 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
https://www.thirdgen.org/forums/body...ant-wiper.html
https://www.thirdgen.org/forums/body...t-fit-rad.html
TGO links seem to be screwed up your gonna have to modify the address when it comes up.
You have to leave enough material to bolt it down and the fender support needs bent a little.
Old Aug 26, 2007 | 09:08 PM
UNCLE TOM's Avatar
perhaps i did not make it clear , i would like to see some pics. of what had to be cut out to put in a 4th gen coolant recovery tank . many people have shown it with the battery in place . i would like to see cut-outs with out battery or tray installed . i just don't want to hack/chop good metal . then i would like to see a pic. of tray installed w/o battery . and any help ?? come on shr00m . help UNCLE TOM out , saw your install in hattiesburg last month and was impressed . super clean and factory looking . help an old phart out .
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
AkDrifted
Aug 17, 2015 07:45 PM
