Coolant lines needed for oil adapter?
Old Aug 28, 2007 | 10:18 AM
camar0rs's Avatar
Are these coolant lines really needed? can i just remove them?
Old Aug 28, 2007 | 04:43 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Coolant lines needed for oil adapter?
camarOrs, are you talking about the 2 coolant tubes that run under the engine from the passenger side to the oil filter?
Old Aug 28, 2007 | 08:36 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
If we are on the same page, yes, you can remove them. I just discovered my `88 Iroc had the factory oil cooler last week when I was replacing the coolant hoses. I bought the car in April of this year and have been unable to get under it to look it over and see what is there. I am going to bypass the factory cooler until I can replace the hoses that attach to it. I`ll use it until the first of the year and then install a fin & plate type oil cooler. The only reason I am a little "edgy" about using the cooler is that it is 20 years old and probably severely corroded inside(the metal tubes are) and I don`t need a breakdown. There is a lot of information about them on this site if you click on "search" at the top of the page and type in "oil cooler".
Old Aug 28, 2007 | 09:44 PM
camar0rs's Avatar
Yes, i am talking about the coolant lines that split off from the passenger side and go under the block to the oil filter adapter...
These are 2 black metal coolant lines, not oil lines....
the main question is that is this really needed? cus i know some camaros dont even have this split off.....
If the lines are removed, what impact should i expect if any? higher/lower oil temps?
Old Aug 29, 2007 | 06:05 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
This was a very strange oil cooler set-up that GM required on certain models, usually `87 and later 350 TPI Iroc/Z28 coupe. The cooler is actually a "heat exchanger", not a traditional oil cooler like we are used to seeing. It won`t hurt to remove it but your oil will run a little hotter. I can`t say how much hotter but I am thinking not much as there are many on this site who have disconnected the cooler without any problems. The original engine in my `88 Iroc had to be replaced by the previous owner with less than 100k miles and he told me the car always ran too hot, so I don`t think these coolers did much cooling at all. I am going to replace my factory cooler with a more traditional cooler after the first of the year. If you decide to remove your cooler and associated parts, save them, someone will want to pay you good money for it. So, go ahead and remove it, you should not have any over-heating problems associated with the cooler. There is an excellent diagram on this site of the factory oil cooler we are talking about.
IROCZ1989
Jan 24, 2016 03:55 PM
Navy8125
Aug 21, 2015 09:32 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Elliswon
Aug 10, 2015 12:33 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
