how do i keep my stock temp guage???
Old Aug 31, 2007 | 08:18 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
i have a 91 tbi that i converted to carb. im goin to run a manual fan switch. i still have all stock gauges and want to keep it that way. what kind of sensor do i need to get to hook up to my stock gauge? before the swap i had a hypertech cooling fan switch that was hooked up on the p/s head. the wire color is green with a white stripe. any info is appreciated thanks!
Old Aug 31, 2007 | 08:27 PM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Re: how do i keep my stock temp guage???
The stock gauge is connected to a solid green wire which connects to a temp sender on the driver's side in the head near the first two spark plugs. It is a completely separate circuit from the fan switch wire which is green and white most applications, usually located on the passenger side on the head above the starter. Charles
Old Aug 31, 2007 | 08:40 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
so your saying its a solid green wire wire that goes to the d/s head, and it should coem fromt he d/s connector on the firewall that goes into the interior correct?
Old Aug 31, 2007 | 09:17 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Correct the solid green lead from the sending unit in the driver side head is for the temp gauge in the dash.You could still use the fan switch in the passenger side head to control the fan as all it does is ground to complete the circuit for the fan.
Old Aug 31, 2007 | 09:39 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
well my new motor dosnt have any sort of sending units. so if i need to go buy a new "sensor" for the drivers side head what is the sensor called?
Old Aug 31, 2007 | 10:21 PM
86WS6's Avatar
The sender/sensor for the gauge/drivers side head is called a tempature sender or sending unit. There are two types of sender's, the gauge type, and the idiot light type. Charles
Old Aug 31, 2007 | 10:57 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
alright thanks for the info. im going to go to my local napa tomarrow and pick one up. ill let you know how it works out
italiano67
Dec 11, 2016 09:21 AM
Genopsyde
Oct 7, 2015 08:35 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
355sbcTPI
Aug 19, 2015 04:38 PM
