Water Pump Won't Come Off!
Old Sep 8, 2007 | 07:54 AM
GTOnTA's Avatar
On my '86 Trans Am I have removed the 4 retaining bolts but the pump won't separate from the engine block.......even with the aid of a 3-foot pry bar!
I have looked at the pic of a replacement pump and I see 4 bolt holes. I had the pump out about 12-13 years ago no problem, The car sits outside but gets driven once in a while in the summer.
Please tell me I missed a 5th (or 6th) bolt that is hiding from me.
Old Sep 8, 2007 | 09:06 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Water Pump Won't Come Off!
First let me say "WELCOME TO BOARDS!!!
I'm almost positive that every chevy V8 built from 1955 up to 1993 or so had only 4 bolts on the water pump. I had mine out to replace it last year and it was a bugger. Sometimes they just get frozen to the block.
Also, on my 84 T/A at least, I had to remove a 9/16 nut for the bracket for the powersteering pump. It's on the drivers side and I had to swivel the power steering pump out of the way. I can't remember if it also held the AC or not but either way, I did not need to remove the powersteering pump (Or AC Compressor). After removing the 4 bolts, there is a hole on the water pump (Drivers side) that a stud goes through and a bolt tightens down to hold that bracket in place. The stud is on the block so you just need to remove the nut to gain access. If you look at how your AC and Power steering brackets are mounted you should be able to find what I'm talking about. If you can't, I'll take a picture and post it for you. Good luck!
Old Sep 8, 2007 | 09:42 AM
GTOnTA's Avatar
Thanks. I've removed the power steering fluid pump stud.
I guess I'll just keep soaking the water pump with PB Blaster and hopefully it will eventually loosen up.
Old Sep 8, 2007 | 09:45 AM
Ozz1967's Avatar
Car: 1984 Trans Am
That stud had me stuck for like 30 minutes until I found it. I was like "Why won't this come off!!!???" lol....That's all I can think of as to why it wouldn't come off. Best of luck to ya. Have you tried a hammer?
Old Sep 8, 2007 | 01:02 PM
GTOnTA's Avatar
Ding ding ding!!! You were absolutely right. That %#@* power steering pump was hiding a bolt I hadn't seen. There are 4 bolts retaining the pump but I missed that one. The water pump is out......finally. LOL
Old Sep 8, 2007 | 03:41 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I'm glad you found it! lol
Old Sep 8, 2007 | 03:46 PM
GTOnTA's Avatar
I was thinking about deleting this thread, but just in case there is another idiot like me who is approaching senility, this info may be helpful.
The good thing about senility is you're always meeting new people. LOL
Old Sep 8, 2007 | 06:22 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
been there , done that . [ at least i think i did , maybe not but i think did ]
glad you found the problem child . LOL
Old Nov 11, 2007 | 11:20 PM
jaseman2134's Avatar
Car: 1987 camaro
Engine: 3.1
good thing you didnt cut this thread lol
i just came across the same problem. thanks
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
