Another thread about electrical fan problems.
Old Sep 20, 2007 | 01:16 PM
'86 350's Avatar
Car: '86 Camaro SC
Allright, about 2 months ago my electric fan stopped working, of course at the worst possible time, when the car was on the dyno.
I've checked multiple things that could be wrong. I followed all the wires, since this isn't the original engine/radiator, it's not wired like stock. I followed every wire that came from the electric fan, and all the wires tested out fine with no breaks or anything. There are 2 wires from the motor and they go to a temp sensor (at least I think it is) that's in the radiator (unfortunately I broke the sensor getting the radiator out).
The other one goes to a relay. Then off of the relay there's a wire going to a fuse, I can get a picture if anyone needs one. I replaced both the relay and fuse, and still no go on the fan working.
I've pulled the fan now, and I put the 2 wires coming off the motor up to a battery. I tried both ways, and no matter what the motor won't work. So from this i'm assuming my motor on my fan is bad. Only problem is, I can't seem to find this part number anywhere, i've tried a bunch of places online and everything.
The part number for the motor itself is: #22051014 and then under that is says 106 86. The motor says Delco Products on top of it. Then the actual case that the motor/fan blades sit in is Delco part #: 22040916
Can anyone figure out where I could find these parts or at least what I could use to replace them?
-Thanks, Brandon
Old Sep 20, 2007 | 02:17 PM
Andy89GTA's Avatar
Car: '85 Berlinetta Hardtop
Engine: 388
Re: Another thread about electrical fan problems.
They have the fan motors here last time I checked: www.napaonline.com
I ended up replacing one of my dual fan motors (it was sqeaking and vibrating) with a motor from a single fan setup. They're interchangeable as far as I know.
Old Sep 20, 2007 | 04:22 PM
'86 350's Avatar
Car: '86 Camaro SC
I didn't get any hits on that website with the Delco fan #, and when I typed in "cooling fan" all I got was complete fan assemblys.
Old Sep 20, 2007 | 04:28 PM
Andy89GTA's Avatar
Engine: 388
Type in this NAPA part number: BK 6551588
Old Sep 20, 2007 | 06:16 PM
'86 350's Avatar
Car: '86 Camaro SC
Awesome, that looks exactly like what i'm looking for.
Thanks man!
64goatman
Sep 9, 2015 01:09 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
