well need advice on fan switch
Old Sep 21, 2007 | 12:51 AM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
wel i need some advice .
im going to buy a fan switch since mine crapped out and im wondering which temperature range i should get?
keep in mind that cooler is always good but i dont want to effect the temperature operating range while in the cold new york weather.
http://store.summitracing.com/partdetail.asp?autofilter=1∂=HYP%2D4026&N=700+4294924500+4294860934+4294908216+4294908198+4294924930+4294840140+115&autoview=sku
http://www.mamotorworks.com/corvette.html?frame=1.944
http://store.summitracing.com/partdetail.asp?autofilter=1∂=JET%2D60600&N=700+4294924500+4294860934+4294908216+4294908198+4294924930+4294840140+115&autoview=sku
i was thinking about getting the 200 on and 185 off .
Old Sep 21, 2007 | 04:22 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: well need advice on fan switch
What stat?
Old Sep 21, 2007 | 01:11 PM
eschevyrda's Avatar
Car: 89camaro rs
well i run a low stat now
im going to keep it at a low stat
the one i have is a 140
Old Sep 21, 2007 | 02:52 PM
Ok, you're going to have 140 while moving then, but at a standstill (doesn't matter how cold it is outside) the temp is going to crawl up to 200, the fan starts and brings it down to 185 before it stops, and when you start moving again it's going to drop to 140. That's quite a large temperature swing and I don't know how your engine is going to respond. I'd suggest getting a switch closer to the stat temp. Or why not run a 180 stat? When it's cold outside you'll want some heat in the car, and it's better for the engine too..
Old Sep 21, 2007 | 05:17 PM
eschevyrda's Avatar
Car: 89camaro rs
yea im might just get the 200 on and 185 off i might raise the stat im going
to experiment
so this might be an issue on how cold the car might run while still being in operating range but still not to dam hot
GTAman
Mar 15, 2019 11:40 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
stalkier
Aug 21, 2015 01:54 AM
TA8487
Aug 16, 2015 12:21 PM
