How to wire an electric fan?
Old Oct 12, 2007 | 10:19 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
I just bought an electric fan from another 3rg gen to replace my mechanical fan but I need to know how to wire it. I dont want a hack job like running a wire from my fuse box all the way to the fan or from the battery to a switch inside my car. Do I need a relay and if so what kind do I need? I want it to run all the time as I have no temerature thermostat.
Old Oct 13, 2007 | 09:30 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Re: How to wire an electric fan?
first off...you do not want your fan to run constantly.second i wired mine to opperated off a switch on my center concol.it is a clean simple almost un-noticable mod,depending on the installer.
Old Oct 15, 2007 | 06:10 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Get a 190'C temp switch (for a SBC), 1 40 AMP relay, 7m 10 guage black wire, 5m 10 guage red wire and a pack of spade connectors then PM me for a wiring diagram and some help on what to do from there.
EDIT: oh and antifreeze w/rust inhibitor coz you are gona loose some when installing the temp switch.
Old Oct 15, 2007 | 11:59 PM
4playta's Avatar
Car: 1984 Trans Am
I bought a universal thermo switch and relay kit from autozone, it came with wiring diagram and looks pretty easy, I will be installing it this weekend.
Old Oct 17, 2007 | 12:06 AM
VenomX-87's Avatar
ah cool, let us know how it goes.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
stalkier
Aug 21, 2015 01:54 AM
