Stroker cooling question
Old Oct 16, 2007 | 10:06 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I heard that if you put a 160 stat and a lower temp switch along with a aluminum radiator that your car might not get up to operating temp. I currently have the 160 stat, and will be investing in a aluminum radiator and a 160 fan switch, will this allow my 383 to get up to operating temp or not. Anyone with this kind of setup let me know what works. Thanks
Old Oct 16, 2007 | 10:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Stroker cooling question
It'll get to 160, at least.
Old Oct 17, 2007 | 02:11 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Will this be to cool for the motor?
Old Dec 3, 2007 | 04:54 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
no, 160 should be fine but i wouldnt want to run it any lower than that.
Old Dec 4, 2007 | 09:36 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
160 is when it starts to open. it will be fully open around 175-180. i've heard people say (mainly the guys on the diy prom board) that when running a 160 stat you need to do some tuning to it. i never confirmed that statement or if it was just meant to change your fan turn on/off temps. i use a 180 stat, and i never go over 195 F*.
Old Dec 5, 2007 | 08:29 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
what do you trap in the 1/4
Old Dec 5, 2007 | 06:05 PM
QuickStyle's Avatar
Car: 91 Z28
haven't ran it yet, im hoping for high 11's or low 12's. it will be in that neighborhood
Old Dec 5, 2007 | 07:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i usually run a 160 thermostat and a 167-176 fan switch in the summer, and a 195 thermostat and no fan in the winter and everything stays where it should be.
Old Dec 5, 2007 | 08:01 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
. nevermind what i wrote, im out of it.
i dont see your computer caring much tho, maybe in open loop if anything, but not closed, i guess if anything the motor could run cool enough that it never reached "hot temp"
so isnt going into closed loop.
that would be the only possible issue, but good luck keeping your motor that cool
chazman
Aug 28, 2018 03:25 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
