need pics of alum radiators mounted in car!
Old Oct 23, 2007 | 04:39 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
hey guys im tryin gto figure out how i want to mount my radiator. id like to stick it in the core but i want to see some pics of some done. mostly just the top part at the top of the core. if i can set the radiator in the core it gives me perfect room to mount the turbo and 5" exh.
Old Oct 23, 2007 | 04:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: need pics of alum radiators mounted in car!
i can get some better pics if you want, this is what I did. I lowered the lower support about 3" and managed to tuck most of the top of the radiator under the top support.
Old Oct 24, 2007 | 08:20 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
thats deffinatly the rout i want to go. what size is your rad. it needs to sit evan with the core support if possible. that way the turbo and exh will clear well.
Old Oct 24, 2007 | 08:24 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
If you can fabricate a new upper radiator support (black plastic holding the top in place) and tilt it back some you could have more surface area for the air to cool and thus more cooling. might work to cool an intercooler better too. Then again if it's a 2 row or 3 row alumn rad then you will have no problems cooling it.
Old Oct 24, 2007 | 08:32 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
it will be alum rad. the motor will be ran on 116 with no intercooler.
Old Oct 24, 2007 | 08:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its the direct replacement 2 core radiator from jegs, summit sell them too, they are made by northern.
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Elliswon
Aug 10, 2015 12:33 PM
MENINBLK
Aug 5, 2015 11:58 PM
