Coolant temp vs. oil temp
Old Nov 5, 2007 | 09:27 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I recently put in a oil temp guage and now have a couple questions. Is it normal to have an oil temp of 240, and the stock coolant guage is telling me the engine temp is between the 100 mark and the 220. I dont think that the oil temp should be that high
Old Nov 5, 2007 | 10:24 AM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
Re: Coolant temp vs. oil temp
oil will hold more heat than water typically so that seems about right
Old Nov 6, 2007 | 12:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
240 F is nothing for oil.
Old Nov 6, 2007 | 04:10 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
what would be the operating range for oil temperature
Old Nov 6, 2007 | 07:06 PM
That sounds about right...
The oil gets heat put into it from several sources (bearing friction, or actually viscosity which is a kind of friction; bottom of the pistons; ropcker ***** which is HUGE) and no way for the heat to get out except for splashing up against the water-jacketed places on the inside of the block.
It's normal for it to run anywhere from 30 to 60 degrees hotter than the coolant.
Roller rockers ALONE will bring the oil temp down by as much as 15°.
Your oil temp is basically just about normal. Nothing unusual, nothing to worry about at all.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Stryker412
Sep 20, 2015 06:59 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
