stock electic fan
Old Nov 7, 2007 | 01:24 PM
iroc3o5's Avatar
stock electic fan
i want to swap the stock electric fan from my 86 camaro sport coupe over to my 86 monte carlo ss. i read some where the camaro fan brackets will swap over fine, but how is the stock camaro electric fan turned on? i know if i turn my a/c switch on, it turns on, and i presume it comes on at a certain temperature as well. i want this fan to run like it does presently on my camaro, i dont want to bother with hard wires or switches in the ashtray that can catch on fire.... any help would be appreciated. btw my monte carlo ss has a clutch fan (belt driven) stock.
Old Nov 8, 2007 | 05:33 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: stock electic fan
Just curious why you would want to replace the fan in your Monte Carlo with an electric one? I`m not sure about your `86 Camaro but in `88 with dual fans the primary fan is turned on by the ECM (computer).
Old Nov 8, 2007 | 05:36 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
the G bodies never had electric fans. I thought i wrote on this already, you did not get the answer you wanted?
lots of parts from f bodies fit on G bodies but i'm not sure about that specific one. I'm pretty sure the camaro rad is smaller, thus the upper support may not fit thus the fan won't.
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Genopsyde
Oct 7, 2015 08:35 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
