will this hurt anything??
Old Nov 11, 2007 | 09:45 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
ok my water outlet is crack and leaking and cant find one with out ordering.so what will it hurt if i took the thermostat out? it shouldnt leak then cus there wont be any pressure and yes this is temperately until the new water outlet comes in...
Old Nov 11, 2007 | 11:40 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: will this hurt anything??
if its just a small leak, use some bars leaks.. it'll seal it right up.. if you do that, make sure you read and follow the directions correctly..
Old Nov 12, 2007 | 08:52 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
even without a thermostat it will still build pressure and leak as soon as it gets warm, it builds pressure due to heat not do to having a thermostat. Don't use any leak stopper crap, just fix it right and avoid clogging something up. If its just the waterneck with a hairline crack in it and you need a temporary solution take it off fill the crack with some strong 2 part epoxy and it should hold up until you get a new one.
Old Nov 12, 2007 | 10:21 AM
alpine247's Avatar
Car: 1988 IROC-Z
well im going to see if i take the thermostat out if it will stop leaking..cause im tired of smelling and adding anti-freeze/water every day.the new water outlet wont be here until thursday..
redmaroz
Apr 25, 2017 07:14 AM
92GTA
Apr 9, 2016 07:39 AM
Stroopwafel
Sep 11, 2015 06:38 AM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
