my 85 trans am overheats when sitting?....
Old Nov 18, 2007 | 02:54 PM
mrgoopey's Avatar
I have an 85 ta that when im idling or driving under 35 mph it slowly overheats, but when im going at higher speeds it fine. I just changed the coolant and thermastat, the heat works, so whats making it get to 260 degrees.
Old Nov 18, 2007 | 03:23 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: my 85 trans am overheats when sitting?....
Sounds like the radiator fan is not operating properly. The rushing air is keeping the engine cool at speed. Do you have an electric fan or clutch belt-driven fan?
Old Dec 16, 2007 | 04:20 PM
Garconer's Avatar
Car: 1986 Camaro
Engine: LG4 305 w/ Qjet
Axle/Gears: 2.73 10-bolt
I had the same problem on my 86 camaro's electric fan, it was the temperature sensor that went bad. This may not be your problem, but it could be a place to look.
Old Dec 23, 2007 | 10:39 PM
Ronzo's Avatar
Car: Toyota 4runner
Engine: 2.4 22-RE
check for crap in the radiator fins
Old Jan 6, 2008 | 08:42 AM
jake wagoner's Avatar
mine does the same only it goes up to 220ish which is perfectly normal but your water pump might b bad also though i would guess the radiator is plugged or fan isnt pullin as much air as it should
Wylecoyote08
Nov 6, 2015 03:46 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
lakeffect2
Aug 23, 2015 08:44 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
