*Ideas* Performance Radiator Install??
Old Dec 8, 2007 | 02:46 AM
Drone358's Avatar
Hey guys, 92 RS Camaro.. going Old Style 350 80's Block, Bought a universal Radiator for this thing and its a 3 core... 31" x 19" Its too tall and only thing i saw to do was lower the Bracket on the bottom... do yall know how far it is from the ground or how much.. maybe around 3 to 4" , I got a cuttin torch and a welder, so Please let me know... I got alot of other questions too about switching from computer to jus regular hard wiring.. wondering if anyone has done that?! Thanks guys!
Old Dec 8, 2007 | 07:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: *Ideas* Performance Radiator Install??
as far as the lower radiator support, just hold the radiator up next to it and see how much lower you have to make it, its not rocket science. I lowered mine a few inches to better fit a 2 core "direct replacement" radiator, i just cut the support off with a sawzall, bent up some new mounting "cups", welded it back together and had a custom upper support made. A cutting torch has no use on metal this thin.
as for the wiring, its been done. the computer works many things in the later cars, so you will have to do a bit of re-wiring to get everything working again, i assume you are going to use a carb?
Old Dec 11, 2007 | 11:44 AM
Drone358's Avatar
yea im using the carb... its an old 80's model block.. but thats how i like em ya know..lol But thanks for the input, th re-wiring is gonna be crazy.. wondering if i could jus get a painless wiring harness jus for like 8 accessories or something like that??
Old Dec 11, 2007 | 06:17 PM
Drone358's Avatar
thanks for the pic man
Old Dec 11, 2007 | 07:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
I believe the wiring between birds and camaros are close/the same. If you have the engine out, you can remove all the wire-loom and trace things. There is a large harness that comes out of the driverside firewall, that does all the headlights, you can trace it through a couple relays on the fireway and then down to the front of the car and under the nose support and over to the other side, all lighting. the passenger-side fender well, right behind the a/c blower, there is another large harness there. Just about everything there goes to the computer, there are also wires in there that go over the engine and into the trans tunnel for the lock-up and speed sensor if so equipped. I dont know what you are trying to keep as fas as accessories, bet you can just start tracing wires and see where they go and eliminate them as needed, if you have no care for emissions equipment of the old fuel injection is using a carb. It can start to look like quite a spiders-web of wires, but if you stare at them long enough, it starts to make sense.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
