big block hose ?
Old Dec 22, 2007 | 03:39 PM
z502's Avatar
big block hose ?
i have a big block on 84 camaro, radiator griffin 31x19 and i cant find the lower hose !!! thanks
Old Dec 22, 2007 | 05:29 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
Re: big block hose ?
i used a universal one the first time. I took it to a napa store and they matched it up with a hose from a 77 dodge truck with a 360. hope this helps
Old Dec 23, 2007 | 03:31 PM
z502's Avatar
tanks a lot
Old Dec 23, 2007 | 04:36 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Have you tried spec-ing a 2nd gen big block hose? I found that when I put an olds engine in if I used a 79 T/A radiator hose it fit pretty well.
Maybe you could check to see what a 70-73 Big block Camaro lower hose looks like...
Old Dec 23, 2007 | 09:48 PM
RazinCayne's Avatar
Car: 92 Z28 / 66 Biscayne
Engine: 355 / 427
Transmission: T5 / M22
Axle/Gears: 3.42 Posi / 3.73 Posi
I did a Vega V8 swap sometime ago. What I did was take a wire clothes hanger and configure what bends & how long I needed from the water pump to radiator along with the diameters and took that to my local Napa Store. Five minutes later I was on my way home with a hose that fit perfect.
Just a thought
Merry Christmas
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
Nick McCardle
Sep 10, 2015 08:36 PM
