oil smoking??
Old Jan 24, 2008 | 10:55 PM
rangerlaxdude's Avatar
Car: 85 berlinetta
Engine: 350 carb
Transmission: 4 speed auto
oil smoking??
so for the past couple of days i have noticed a very very small amount of smoke coming from the engine i finally had the time to look at it and i found it was coming from the oil dipstick! what could be a the cause of this and a possible fix?? thanks!
jeff
Old Jan 25, 2008 | 10:15 AM
xbcrguy182x's Avatar
Re: oil smoking??
Is it coming from the top of the dipstick tube? If it is, you overfilled the engine with oil.
Old Jan 25, 2008 | 01:56 PM
Car: 85 berlinetta
Engine: 350 carb
Re: oil smoking??
yea thats where its comming from but i checked the oil level and it was a little low
Old Jan 25, 2008 | 05:08 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: oil smoking??
the first thing i would check is the crankcase vent system . new pcv valve , new vent hoses , if tbi filter inside air filter housing . how many miles on eng. ? has it set up for long periods of time ? i had similar problems will mine several years ago . changed valve seals , de-gunked heads ( in car ) , cleaned oil drain passages on front and rear of cylinder heads . problem solved . good luck .
db057
Apr 28, 2019 07:45 AM
69GTOby
Apr 18, 2016 02:34 PM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
Stryker412
Sep 20, 2015 06:59 PM
Accerrito22
Sep 5, 2015 09:34 PM
