Cooling Issues?
Old Feb 11, 2008 | 10:01 PM
Brokenpath's Avatar
Cooling Issues?
I just bought a 1992 camaro RS v6.
Upon opening the hood after taking it home i noticed bubbles and electrolysis around the thermostat housing. Shortly afterwards i replaced those parts. Even put a new gasket with silicone.
A couple days ago i also replaced the water pump.
The car no longer overheats, but the temperature seems to fluctuate.
from about the 220 mark in the middle, It'll go to the next line over to the right and hang there until i accelerate and then it goes back down. At night, it typically does the exact same thing and goes back to the middle.
It doesn't smoke at all anymore or smell like boiling coolant.
I was just wondering if that temperature fluctuation was normal or not.
Old Feb 12, 2008 | 02:44 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Cooling Issues?
sure, it can be normal, it depends on coolant flow and accuracy/sensitivity of the temp sensor and guage
220 and under is fine
as long as the fan is doing its job pulling air through the radiator well,
and the radiator is not old/rotten/restricted,
and the cooling system is holding 15/16lbs of pressure when hot and even for a while after the when the engine is shut off,
then all should be well
and also the air dam underneath the rad support needs to be complete and intact as well
good luck
Old Feb 13, 2008 | 10:30 AM
xbcrguy182x's Avatar
Re: Cooling Issues?
I wouldnt worry. Stock gauges are not always accurate.
Old Feb 13, 2008 | 07:30 PM
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
Re: Cooling Issues?
I agree with xbcrguy, however, you may have a low coolant issue from filling it up and not getting all the air out of the system. I have seen this happen before where the fluid cycles air through and makes the reading go falsely cold when the air passes the sender. This will be most apparent when running at driving speeds (rpm in the 1800+ range) and then when you slow down. Remember when you fill up your cooling system that the car needs to run until the thermostat opens and then hold the idle up and top it off. The thermostat will be open when the top hose gets hot. If this is not the problem, also remember that when outside air temperatures are coldest, the guage will be more apt to fluctuate because the air is cooling down the coolant so much that the thermostat can actually cycle closed while you are driving and then open back up. This also could account for the guage fluctuation.
Old Feb 14, 2008 | 09:02 PM
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
Re: Cooling Issues?
Not a hijack but dang, you guys made me feel alot better about my car. I have the same problem. Thanks!!!
Old Feb 15, 2008 | 09:12 PM
Brokenpath's Avatar
Re: Cooling Issues?
Thanks a lot guys. I'll probably flush the system.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
