A/C Issue.
Old Feb 14, 2008 | 11:02 PM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
A/C Issue.
Hello All,
A lot of the parts of my A/C system need to be replaced. Should i just screw the A/C and take it out all together? If so, how would I go about doing this.
THANKS!!!
-Andrew
Old Feb 15, 2008 | 08:30 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: A/C Issue.
well, you could look at it from a cost perspective. compare an a/c delete kit and labor with replacement a/c parts and labor. might also be worth taking it to an a/c shop for their opinion on what's actually wrong with the a/c before yanking it
Old Feb 16, 2008 | 01:30 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: A/C Issue.
Leave it in. It's free that way. Can always fix it later if you want.
Personally I wouldn't want to buy an F-body without A/C. If it's broken that's one thing. But having no A/C at all in there, I'd pass.
Old Feb 16, 2008 | 07:47 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: A/C Issue.
I agree on keeping it. Having a/c on these cars is a big plus anymore. Especially if it works. What exactly needs replacing on the system? Most of the parts aren't that expensive actually. Sometimes it just ends up needing to be recharged because o-rings have dried up and leak or shrader (sp?) valves allow it leak down. Both those cases cost about $10 in parts and maybe an hour of labor to pull vacuum on the system and recharge, though the refrigerant is about $60 a pound/can now, so it runs about $120 for that. But if the system will hold it and not leak back down, it costs less than converting it to 134-a, which is less efficient and doesn't blow as cold.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Lmancha96
Sep 25, 2015 08:11 PM
Mdenz3
Sep 17, 2015 08:36 AM
