305 compressor
Old Feb 24, 2008 | 09:17 AM
Radiorick's Avatar
Car: '89 t-bird SC/87 Z-28 vert
Transmission: auto
305 compressor
I have an '87 camaro vert w/305. My a/c compressor is bad and there is one on ebay out of an '87 305 w/tpi. Is this the same a/c compressor as one in my 305 with a carb? Are all the 305s a/c compressors the same? Thanks Rick
Old Feb 24, 2008 | 12:26 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: 305 compressor
More than likely yes. If it the same shape and design (looks the same), it should work. The problem with buying a compressor online is you don't know if it still good...you'd be taking his work for it. Also, has your a/c system been open? Or is the compressor just bad and you are waiting to buy a new one before opening up your system? When you open the system, you also have to replace the accumulator or receiver/dryer too. Getting a new or reconditioned compressor isn't that expensive from a parts house and you know it will work or they will take it back and replace it with a good one. I would just hate to see you go through all the work of replacing the compressor, adding oil and refrigerant to it to have to take it all back apart again. Especially if you use R-12 which is like $60 a can now...
Old Feb 24, 2008 | 01:43 PM
Radiorick's Avatar
Transmission: auto
Re: 305 compressor
Thanks for the help. Any good places on line to pick one up? Rick
Old Feb 24, 2008 | 02:24 PM
Car: '87 Trans-Am
Re: 305 compressor
Autozone or Advance Auto has them...usually for under $75. At least that way you have the local parts store there to return it to if something is wrong.
Old Feb 24, 2008 | 02:48 PM
Radiorick's Avatar
Transmission: auto
Re: 305 compressor
Thanks again - Rick
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
TheTraut88
Sep 7, 2015 05:22 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
