My bro's custom fan switch
Old Mar 2, 2008 | 08:19 AM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
My bro wants to do this custom fan switch. i want to make sure he wont go through the horror story that i went thru....the prev owners of my iroc rigged up a whole bunch of horrible bulls**t that melted down on me, making my car die completely in the middle of the street. i had to get the entire cooling circuit and starting circuit rewired.
but anyway plz give me any warnings so i can save my bro some trouble
Old Mar 2, 2008 | 08:30 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: My bro's custom fan switch
No. The fan draws too much power to run through a switch.
If you don't have electric fans now your best bet is the stock relay setup from a jy. The stock relay is provided a 12v control when the ignition is on and grounding the relay passes power to the fan. The stock relay is grounded by the temp switch or the A/C pressure switch to engage the fan with high temp or A/C operation. Retrofitting this setup to an earlier model with mechanical fan is easy. To manually turn on the fans you can jump the control ground through a switch to ground.
I'd advise against using ONLY a switch for fan operation. Installing the temp sensor in the head is an inexpensive failsafe and a cockpit switch can still be used.
Old Mar 2, 2008 | 09:14 AM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Yea . You can just hook up a switch to ground out the relay.. Better to do it that way. If you have a heavy enough switch you can just use a switch..But thats not the right way. Wheres your fuse in the pic??
eightsixseven
Dec 16, 2024 01:50 PM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
Dialed_In
Aug 20, 2015 01:45 PM
TA8487
Aug 16, 2015 12:21 PM
