manual cooling fan switch?
Old Mar 14, 2008 | 08:58 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
can someone please tell me how to hook up a manual fan switch, other than just buying a kit?thanks
Old Mar 21, 2008 | 12:20 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: manual cooling fan switch?
If you haven't already accomplished this, all you'll need is a long piece of wire, a short piece of wire, and a toggle switch.
Splice the long wire into the wire that's connected to the fan switch(located in the passenger side cylinder head between the back two spark plugs); then run that wire into the car(however you want to get it inside) and connect it to one prong on the toggle switch; connect the short wire to the other prong on the toggle switch; connect the other end of the short wire to the metal frame underneath the dash to ground it; mount the toggle switch wherever you like; and you're finished.
Old Mar 21, 2008 | 08:11 AM
i ended up doing somthing like that only through a relay. thanks for the response -Art
Old Nov 19, 2013 | 02:10 PM
ZoSoCamaro89's Avatar
I know this is a super super old thread but I just did this today and it is by far the simplest explanation for this issue. I've poured over a lot of searches to find this one.it took me all of 20 mid to do after reading. mods I think you should make this a sticky. Btw if your car doesn't have stigma fog lights that's a great place to put the switch right under the headlight control you can even find a head light bezel with the fog switch already in it to keep everything looking stock
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
