Possible to manually run both fans with one toggle switch??
Old Mar 24, 2008 | 04:14 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
A couple summers ago I spliced the ECM fan wire (green wire from the relay) and ran a wire to a toggle switch in the dash. Works fine.
Now, my temp switch controlled fan isnt working. Thought it was the motor. Replaced that and still not working. Now I believe the temp switch in the block burned out.
Rather than replace the switch (kind of a pita) can I just run a wire from the connection at the temp switch to the same toggle in the car and be able to manually turn both fans on at the same time?
Old Mar 24, 2008 | 04:32 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Re: Possible to manually run both fans with one toggle switch??
doing the temp switch from under the car is the fastest way and easy to. Well if your car is a V-8 at least ... provide a ground with your toggle switch to the fan relays green wires and they will come right on.
Old Mar 24, 2008 | 05:29 PM
It is a v8. I already have a ground from my toggle to the secondary fan relay up by the firewall.
Sorry to make you clarify, but does the primary fan have a wire at this relay also?
Old Mar 25, 2008 | 05:04 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I spliced into the wire that comes out of 20 amp fan fuse, ran it to a switch and then ran that to the hot side of both fan and grounded the fans to the frame. That worked fine until I had to upgrade to a higher output fan and shroud setup
Old Mar 25, 2008 | 05:35 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
thats how mine is done,but both fans draw alot,headlights dim a little with both on,so i just unpluged 1 of them,dont really need both on,i have no a/c
Old Mar 27, 2008 | 08:31 PM
DPSJosh's Avatar
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
Make sure you are running your switch on the CONTROL side of a relay, not a side where you are pulling high current, as the switch will get hot and melt. Other than that, yes, you can run almost anything on your car with a switch.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
RazorN8
Jan 7, 2022 11:44 AM
dhonda200
Aug 11, 2015 11:50 PM
