Automatic vs. Manual Running Temp?
Old Mar 25, 2008 | 06:24 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
i recently went from a 700r4 to a t10. w/ the auto my car ran cool,now it runs warmer. for ex. with the auto i barley ever had to turn the cooling fan on, now the fan almost always needs to be run even on the hwy. im still using the auto radiator. does this make a diff? please respond. thanks -Art
Old Mar 25, 2008 | 10:48 PM
Re: Automatic vs. Manual Running Temp?
lower hose partially colapsing????
Old Mar 26, 2008 | 12:19 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Perhaps the higher RPMs caused by lack of overdrive? Just a guess...
No doubt the engine sees different conditions with a manual behind it as opposed to an auto. For example if you let off the gas with the 700R4 at around-town speeds the RPM will drop to near idle and the car will essentially be coasting. However with the manual you have a lot more engine breaking going on, RPM wont drop on throttle lift....I know when I start manually shifting my 700R4 and really start ******* on it around town keeping the RPM constantly up between 3000 - 4500 the temp will start to climb a bit after just a couple minutes of abuse.
You should NOT need your fan on at highway speeds. Is your air damn in place?
Old Mar 26, 2008 | 10:43 AM
yes, the airdam is there.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
kyleb24
Aug 15, 2015 08:24 AM
bamaboy0323
Aug 15, 2015 07:20 AM
