Water Pump
Old Apr 19, 2008 | 08:21 AM
alexc7802's Avatar
Water Pump
The stock water pump on my 92 camaro 5.0 rs is on its way out i was wondering if any one had any opinions on this one, and will i need a regular rotation or reverse, and short or long version I also ahve a 160 thermostat installed and an open element air intake if that matters. thank you.
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 19, 2008 | 11:27 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Re: Water Pump
thats the wrong part number. the one you need is edl-8881. its a long, reverse flow water pump. i have this same one on my 91 305 TBI firebird. as far as the part itself, ive had no problems with it since installation. only problem i had was with the installation itself. the water pump was hitting on the brackets for the a/c and alternator. a little bit of grinding on the sides and it fit right in.
Old Apr 19, 2008 | 12:21 PM
alexc7802's Avatar
Re: Water Pump
thanks for the advice
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
