A/C Problem
Old May 9, 2008 | 11:03 PM
Subnoizebro's Avatar
Car: 1987 Z28 Camaro
Transmission: 5speed
Axle/Gears: 3.08
A/C Problem
I have an 87 Z28 305 5-speed and my A/C and heater wont work. When i set the control to "Max" or what ever setting id like, no air comes through the vents what so ever. Something does turn on when u switch it over and there arent any blown fuses. Does anyone have any ideas of what i can do to fix the problem. Thank you!
Old May 10, 2008 | 04:49 PM
mikeiaz's Avatar
Re: A/C Problem
does it sound like the ventilation fan is running? if not then that is proably the issue - if it is running it could be the vacuum contol switch on the back of the ac/heat switch - it controls which vents open/shut for air flow
Old May 11, 2008 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: A/C Problem
If the air is blowing through the defrost vents, you have a vac problem (defrost is the default). If you have no air there, check the blower motor.
JamesC
my86bird
Oct 23, 2015 12:20 PM
greenyone
Sep 2, 2015 03:39 PM
greenyone
Aug 29, 2015 11:08 AM
BikeFarm
Aug 11, 2015 11:35 PM
