Cooling issues with 880 block
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hi,
I have cooling problems with my -85z.It has 355(880 vortec block).I use waterpump from my previous 305 (standard rotation pump).Thermostat is brand new 180F deg high flow summit unit.It has drilled four 11/64" holes for by pass coolant circuit.
Radiator is Modine 1R951 replacement unit.
Symptom is:car overheats occasionally,it raises temp from ~180F to 260F,but if I give to engine more throttle,temp lowers.It makes this at highway and also when standing still at idle.
When temp raises and I give it throttle,upper radiator hose collapses.Car has lower radiator dam,ignition advance at idle is 25 degrees and a/f ratio is at idle ~15.5-16.5 and at cruise ~14.7-15.5
First I think that it was bad thermostat,and I replaced it to new one,but no difference.Do I need betterflowing waterpump/thermostat or what?
-Jari-
-Jari-
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Cooling issues with 880 block
Hi,
-Jari-
-Jari-
Engine: 385
No,original v-belt system.I replaced waterpump yesterday to Weiand action plus pump(made in china...).Test today how it works.
Is that little hole below bigger hole at waterpump mountingoint at block to by-pass cooling circuit?
-Jari-
-Jari-
Engine: 385
Update:Old pump was defective.No more overheating with new pump.
