broke the radiator fan switch
Old May 20, 2008 | 04:26 PM
Evader15's Avatar
I have a single fan 1985 trans am 305 TPI.
I installed headers and i broke the radiator fan switch, on an attempt to remove the old one to replace it, i ended up breaking off half the copper outside. So, what do i do now? Is there any way i can remove this from the block?
The most i can do is tilt the engine, i cant remove the engine. Thanks.
Edit: Ill get a pic when i can, its hard to explain. Basically none of my wrenches or sockets would do anything but strip, so i tryed te vice grips. Any help appreciated
Old May 21, 2008 | 07:44 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: broke the radiator fan switch
You could wire-up a switch for manual operation or wire it so it runs when the ign is on untill you can come up with a permanant fix.
Does it screw into the block or the head? If it's in the head, it would be a little easier to get "on the bench", to work on it.
If you can still get a decent grip on it with vise-grips, might try some penetrating oil. Give the threads a good squirt and let it sit overnight.
If the penetrating oil doesn't do the trick, then you're probably looking at breaking the top off, drilling it out and re-tapping the hole.
Is there a similiar unused port on the other head? Might be able to use that and extend the wire to reach it.
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
luvofjah
Sep 3, 2015 07:08 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
