Temp gauge not working on 3.1 to 5.7 TBI swap
Car: 1990 Camaro RS
Engine: 5.7L TBI
Transmission: 700R4 w/shift kit
Hey guys, my dad(eds56) and I are trying to finish up our 3.1L V6 to 5.7L TBI swap... However, my temp gauge is not working at all. We are running the V8 Computer and instead of fussing with making changes to the V6 circuit for the CTS, we decided to splice in the actual V8 CTS/MAP/TPS circuit. So I know the circuit and wiring are correct, and we've rung it out multiple times now.
Now I read on here somewhere that when your CTS is going bad your car will run rich(or was it lean?). Ours appears to be running fine. Any ideas?
I also should note that I currently have the V6 Instrument Cluster. I have a 91 V8 Cluster but I have yet to install it. Does that have anything to do with it?
Thanks in advance.
Thanks in advance.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Temp gauge not working on 3.1 to 5.7 TBI swap
Are you talking about the temp gauge on the dash? The computer does not control that one. The one for the computer is in the front of the intake manifold with yellow and black wires.
The one for the dash is a screw-in plug in the driver's side head between the #1 and #3 cylinders. Check to make sure there is the correct wire plugged in there. It has a flat circle connector and the wire slides onto it.
Car: 1990 Camaro RS
Engine: 5.7L TBI
db057
Aug 11, 2015 10:11 PM
