Electric fan always running? computer fried?
Old May 21, 2008 | 11:30 AM
mmather1's Avatar
Hey i have a problem with my 88 tpi , computer 165, when key is on engine not running, the cooling fan doesnt run, when i ground the diagnostic connector it comes on,, also as soon as i start the engine the cooling fan starts running, i check C1 (cooling fan output) at the computer with a test light to 12V and it lights up. I Assume what when the temperature reaches 220 or whatever its supposed to ground C1 to complete the circuit and turn the fan on, But it grounds it as soon as you start the engine.??? IS my computer fried? This is a transplant , is there anyway i have somthing wired up wrong? no Codes are in the computer, but when i have a scanner on it i noticed it doesnt come out of open loop?
Old May 21, 2008 | 07:24 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: Electric fan always running? computer fried?
What is the scanner indicating for the coolant temp sensor (CTS)?
Old May 21, 2008 | 08:22 PM
mmather1's Avatar
The scanner is reading the right temperature (same as my mechanical gauge), it says there is no fan request, when it is on
Old May 22, 2008 | 07:24 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I've burned a few proms. Ever once in a while I'll get a bad burn (or accidentally install the chip backwards), and the fan will come on as soon as the key is switched to run. Might just be a bad prom.
Do any of the other sensors read out-of-whack, like 02, tps, maf?
Old May 22, 2008 | 07:32 PM
mmather1's Avatar
All the other sensors seem to be reading alright, but it does seem to be running awfully rich like you can smell gas out the tail pipes when its running, other then that it seems to run alright too, I just don't want to be running around with a bad computer that might let me down
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
bamaboy0323
Aug 15, 2015 07:20 AM
