Overheating problem on 86 trans am help please!!!!!
Old Jun 15, 2008 | 07:46 PM
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
I have an 86 trans am 305 fi i just rplaced the radiator and put in a new thermostat but it runs at 220- 240 and thats where it stays it does not go down past 220 but will go back up to 240 my fans are working and i put in new coolant when i changed the radiator. if you have any idea wat this might be please help.Name:  IMG_6842.jpg
Old Jun 15, 2008 | 08:48 PM
MADMAXGTA's Avatar
Car: 89 TTA
Re: Overheating problem on 86 trans am help please!!!!!
Sounds like you replaced everything except the water pump,that can make a huge differnce,Im a huge fan of alluminum water pumps.
Old Jun 15, 2008 | 08:55 PM
MADMAXGTA's Avatar
Car: 89 TTA
I had that exact color 87 trans am,(look in the official pics on the home page)anyway this is the pump i had on it and it ran very cool
http://store.summitracing.com/partde...5&autoview=sku
you prolly have a few blades broke of the impeller of the one your running now.
mine would run at a constant 180,what thermo stat did you put in it?
Old Jun 15, 2008 | 09:18 PM
i have replaced the water pump about a year ago and there are no leaks comin from the car at all is there another way of telling if the water pump has gone out
Old Jun 15, 2008 | 09:33 PM
MADMAXGTA's Avatar
Car: 89 TTA
Im thinkin it may still be working,but you may have a blade or 2 busted on the impeller,so it would still flow but not enough.what thermostat did you put in?
Old Jun 15, 2008 | 09:37 PM
i put in a 180 superstat
Old Jun 15, 2008 | 09:42 PM
MADMAXGTA's Avatar
Car: 89 TTA
Is the airdam present? does it cool down to 180 if your moving?
Old Jun 15, 2008 | 09:44 PM
no its staying at 220-240
Old Jun 15, 2008 | 09:49 PM
MADMAXGTA's Avatar
Car: 89 TTA
daymn thats hot,I feel your pain,check to see if your airdam is present and i would definatly try that proform pump,its tight. I noticed you only have a few post is this your 1st 3rdgen?
Old Jun 15, 2008 | 09:52 PM
yea im only 18 ive put 29 lb injectors 58 mm throttle body turbo muffler and a jet stage two chip its pretty quick beat most the *****s out here you kno fun car
Old Jun 15, 2008 | 09:56 PM
MADMAXGTA's Avatar
Car: 89 TTA
cool!,did you take advantage of all the "freemods" listed on this site? such has the tb bypass?? iIm tellin you,get that proform pump!!my 87 305 ran a consistant 180,and the fans hardly ever came on!
29lb injectors!!!??? wtf thats crazy huge,stock 305s have 19lbs,you may have a problem there.
Old Jun 15, 2008 | 09:59 PM
sorry 24
Old Jun 15, 2008 | 10:07 PM
MADMAXGTA's Avatar
Car: 89 TTA
is this 305 stock besides the mods you listed? did it run cooler before you put those injectors in? how long have you owned this car? did you put those injectors in?
Old Jun 15, 2008 | 11:29 PM
i have had the car for a year and its the first time it has ran this hot i was goin up to tahoe and i thought my thermostst went out because i had changed the radiator a lil before i went up there and it was runnin a lil toasty goin up to tahoe and since then its been runnin the 220-240
Old Jun 24, 2008 | 11:01 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
make sure the thermostat isn't upside down.
Old Jun 25, 2008 | 01:08 AM
donaldw's Avatar
Car: 1988 pontiac trans am
Engine: 305 tpi
Axle/Gears: factory
do ur fans come on?
Old Jun 26, 2008 | 09:35 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Here's a list of the things I would start checking:
1. Thermostat. Put the factory recommended thermostat in. Be sure that it opens or closes by putting it in a pot of boiling water on the stove. You can use a lower temp thermostat if you want, but I would not go below 180*.
2. Air dam under car. Check to see that the air dam is on the car. It is the lower spoiler in front. Sometimes these get damaged by tow trucks and parking blocks. Make sure it is pushing air upwards toward radiator.
3. Check to see front of radiator has no obstructions. Look for the plastic components that direct the air to the radiator behind the front bumper above air dam. It should look like a giant vent or air passageway directly to radiator.
4. Fill car up with coolant while running with cap for radiator off. Do this when car is cold and warming up to ensure all air bubbles are out.
5. Watch to see if fans come on when warmed up. If not, start checking for for electrical problem, switches, wires, or sensor. (on passenger side of engine on head).
Common sense things need to be checked like coolant level in radiator not just overflow bottle, and the color of the coolant. It should be bright green. Your car is an 86 and I am not sure if you have a manual fan on that or not... If so, disregard #5.
This should get you pointed in the right direction...
Good luck!
POZ
Old Jun 26, 2008 | 03:56 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
I have an 86 Trans Am as well, it has an electric fan. Unless of course, Canadian 86's were different
Old Apr 26, 2012 | 05:13 PM
79tagio's Avatar
Car: 1985 Trans Am!
Engine: 355 Chevy Crate Motor
Transmission: Non WC-T5. (gonna blow soon)
Axle/Gears: 3.27s
Hey did you make sure u got the rite waterpump? My car did the same thing and it was because my waterpump was spinning the wrong way XD
84z96L31vortec
Aug 20, 2017 12:16 AM
mustangman65_79
Sep 1, 2015 03:51 PM
jbd1969
Aug 17, 2015 07:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
