Need help please FANS not working.
Old Jun 27, 2008 | 07:49 PM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
I have a 91 z28 305tpi and my electric fans behind the radiator do not work. I know one is suppose to kick in once the car is warmed up i think driver side but none of them work at all. How do i fix this is it a sensor, a wire or needs to be replaced?
Old Jun 27, 2008 | 08:02 PM
NW94Z's Avatar
Car: See Sig
Re: Need help please FANS not working.
Could be a number of things. Fan motors have died. Relays gone bad. Wiring is damaged. Fan sensor/ switch is bad.
With the ignition on turn on the A/C. Does the fan kick on? If the fan comes on when you turn on the A/C the problem IMO is probably a bad sensor/ switch. Not sure if the Dual fans on a Z28 are controlled by the ECU via a sensor input or if you have a switch like single fan guys have.
If the fans don't come on when you start the A/C then the problem is with a relay or the fans themselves I think. I'm sure someone will chime in with more info.
$750 L98
Feb 1, 2025 02:25 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
