coolant gauge issues
Old Jul 5, 2008 | 11:39 AM
Canadianguy2006's Avatar
Car: 1990 Trans Am GTA
Engine: 350(5.7L)
Axle/Gears: 3.23 posi
Hey i'm having a problem with my 90 5.7L GTA, i changed out the coolant temp sensor and the thermostat yesterday because the gauge isn't reading the temperature at all it just sits at 40C, i have taken the car for a spin long enough for the coolant to heat up past that but still nothing, could it be the temp sender that is shot?
Old Jul 5, 2008 | 11:49 AM
NW94Z's Avatar
Car: See Sig
Re: coolant gauge issues
I believe the gauge reads of the sensor in the Drivers side head. The sending unit by the thermostat sends temp info to the ECU but the other device not sure what it's called sends temp info to the gauge in the dash. Instead of having a plastic connector that plugs in it actually clips on to a metal post on the end of the sensor.
Old Jul 5, 2008 | 11:50 AM
Engine: 350(5.7L)
so would i need to replace the sensor on the drivers side of the block then?
Old Jul 5, 2008 | 12:27 PM
NW94Z's Avatar
Car: See Sig
If it's plugged in and your not getting a reading on your dash then yes i would suggest replacing that piece for a new one.
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Sep 17, 2015 12:22 PM
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
