what setup moves more air?
Old Jul 7, 2008 | 11:02 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
im almost done with my fiberglass fan shroud and i want to know what will cool better, dual 10's or a single 16"er? i want some input before i cut into my masterpiece. thanks
Old Jul 7, 2008 | 11:45 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: what setup moves more air?
Good question. I have (2) 10's and they are alot smaller and I think they really move alot of air. I have installed an additional fan on the other side of the Radiator to assist with any heating issues. So 1 pusher and 2 pullers. Works good so far.
Old Jul 7, 2008 | 11:46 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
check jegs or summit for fan specs.. some dual 10" setups will flow better than a single 16" and vice versa
Old Jul 16, 2008 | 08:23 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
ibmtech
do you have any pic's of your setup....having issues
Old Jul 16, 2008 | 09:00 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
It will depend on the fans, but I would think a pair of 10's could match a single 16. With a pair of them, you have the option to bring them on at different temperatures, and only have to run one of them under light loads.
Old Jul 16, 2008 | 09:56 PM
thats what i was thinking too, i just wanted to get a little input before i cut holes in my TRICK shroud i fabed up out of fiberglass.
Old Jul 17, 2008 | 06:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
permacool makes good cooling fans with the little pancake style motors, i have a 14" and a 12" one and both are rated at 3000cfm apiece, thats more than some dual fan setups from just 1 fan.
Old Jul 17, 2008 | 06:20 PM
im looking at a 10 and a 12". ill run the 12 off the low temp fan switch, and the 10" through a relay and a toggle for when i need a little extra cooling. sound about right?
stalkier
Dec 6, 2015 11:25 PM
db057
Aug 22, 2015 08:17 PM
AkDrifted
Aug 17, 2015 07:45 PM
perZ
Aug 15, 2015 01:17 PM
