stupid question
Old Jul 10, 2008 | 06:02 PM
schmeck11's Avatar
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
stupid question
A short neck water pump has the gap behind it and the long does not? is this correct? so stock 82 TA 305 had?? any help is appreciated
Old Jul 10, 2008 | 06:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: stupid question
If by gap you mean a space between the block and the pump, then they both have a gap. A long pump has its pulley mounting surface farther from the block than a short one, ie. the long pump is long and the short pump is short.
Stock, all thirdgens use long pumps. Cars with V belts use standard roation and cars with serpentine belts use reverse rotation.
Old Jul 10, 2008 | 08:48 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
Re: stupid question
so it has nothing to do with how long the neck is. so how do you know when to use a short or a long? or what is the reasoning for 2 pumps roughly 1 inch in depth apart?
Old Jul 10, 2008 | 11:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: stupid question
It has everything to do with how long the neck is.
You use a long water pump if you're using a long-waterpump-style accessory mounting system, and a short water pump if you're using a short-waterpump-style mounting. The short water pump was used up to 1968 in passenger cars (except the Corvette, which used it longer), and the long water pump was used exclusively afterwards.
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
