Bars Leak
Old Jul 13, 2008 | 04:34 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Bars Leak
Is bars leak something that you want to use once and then flush the system? If my car sits for longer than 10-15 minutes im already and 220 degrees and I wonder if that stuff being in there prevents good flowing. Any thoughts?
Old Jul 13, 2008 | 04:56 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Bars Leak
A bandaid approach to something that needs reparing.
Old Jul 13, 2008 | 05:10 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: Bars Leak
what do you mean
Old Jul 13, 2008 | 06:02 PM
DJP87Z28's Avatar
Re: Bars Leak
Originally Posted by stevenb
what do you mean
If you have a leak, repair it and get the cooling system flushed and new coolant added. That may lower your temp, but 220 ia not that hot for these cars in trafic. Also check the thermostat (180 deg is better ) and and the air dam is still in place.
Old Jul 13, 2008 | 06:58 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: Bars Leak
Yes I have the 180 degree thermostat
Old Jul 13, 2008 | 10:42 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Re: Bars Leak
Do you have a leak or are you just getting hot?
Bars leak is just a stopleak product. It won't do anything to help your cooling (except temporarily stop leaks).
Unless you've modified your cooling system, 220 when stopped for a while is not out of the ordinary. On a stock cooling system, the cooling fan(s) are not even running yet at 220.
Turning on the ac should activate at least one of the cooling fans. I always turned on my ac to lower the temperature, before I changed my fan switch to a lower setting one.
Old Jul 16, 2008 | 03:16 AM
donaldw's Avatar
Car: 1988 pontiac trans am
Engine: 305 tpi
Axle/Gears: factory
Re: Bars Leak
what is it been ored out to 30 40 over?
Old Jul 16, 2008 | 03:56 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: Bars Leak
it has been bored 40 over, and i used it to stop a leak of course. I dont have ac to turn on and i just was wondering if i could get a better temp with new coolant. I know 220 is bad but im sure if i let it go thered be no stopping it
Old Jul 16, 2008 | 07:58 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Bars Leak
so it keeps rising past 220? do your fans come on and stopthe rise?
Old Jul 16, 2008 | 08:07 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Bars Leak
Flush that crap out of there and fix the leak the right way. 220 is normal though, it should go all the way up to 230 than the fan(s) should kick on and cool it down. Stop leak products are a big no-no, they are known the not only stop leaks but plug up heater cores etc.
Old Jul 20, 2008 | 07:24 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: Bars Leak
yeah i meant 220 isnt bad...and i have a mech fan with a 3 inch spacer.
J-money
Jan 4, 2019 09:45 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
bubbaz28
Sep 18, 2015 02:09 PM
87camaro87
Sep 9, 2015 10:29 PM
IROCZDAVE (88-L98)
Sep 6, 2015 06:23 AM
