Found my coolant leak...Now how do i fix it...
Old Jul 17, 2008 | 07:22 PM
Keepin This One's Avatar
Car: 1988 iroc/2000 saab 9-5
Engine: 355 tpi/Roller cam
Transmission: 700r4/2800 stall,megashifter
Axle/Gears: 3;42
Found my coolant leak...Now how do i fix it...{pics}
Hello all,
Well,ill try to keep it simple.
Ive been loosing coolant,and ive finally located where the leak is..
Ive got a stock radiator,88 iroc 350 tpi.
On the radiator,inbetween the trans cooler,is a small plastic thing,really cant descibe what it looks like,but it turns slightly,and it leaks.
Anyone know what this is,and whats its purpose?and how to repair it?Is there a oring or something?
Location is aprox.halfway down the passenger side on the radiator,inbetween where the cooler lines hook to it.
Thank you for any help in advance.
sean g.
Attached Thumbnails Found my coolant leak...Now how do i fix it...-irocy-002.jpg
Last edited by Keepin This One; Jul 18, 2008 at 05:46 PM. Reason: pictures, thank you
Old Jul 31, 2008 | 11:29 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
Re: Found my coolant leak...Now how do i fix it...
It is the location for a sensor. Your local radiator shop should have a replacement plug for it. Not sure how it goes in, but I saw on at the shop and he told me they sometimes leak and he had replacement plugs on hand.
Old Aug 10, 2008 | 08:10 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
usually has a metal c-clip that holds them in,another 0-ring unless it is cracked
eightsixseven
Dec 16, 2024 01:50 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bjpotter
Aug 12, 2015 06:06 PM
marcusaw
Aug 10, 2015 08:13 AM
antares57
Aug 6, 2015 07:47 AM
