92 with a leak
Old Jul 27, 2008 | 10:02 PM
camarodude9d2's Avatar
Car: '92 Camaro
Transmission: automatic
92 with a leak
somewhere i have a leak in my 305 RS '92 Camaro. it seems to be drinking coolant and appears to have no drips on the ground. there is some green- yellow residue (i use the green-yellow coolant) below the intake near the water pump.
what are the common problems of that year
it has 136k miles and a daily driver, which is not much, mostly short drives.
if there is a fix could an 18 year old fix it with limited engine experience and how much would it cost?
Old Jul 27, 2008 | 11:32 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: 92 with a leak
there is a lot of things in that area that could leak. it could be the hose or the t stat housing if there is residue on the intake. if there isnt some there it could be the waterpump gasket or if ur pump is bad it could be the weeping hole. if its the original pump it probably is past its prime. none of those leaks are too hard to fix
Old Jul 28, 2008 | 06:33 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 92 with a leak
most auto parts stores have system press. testers . many will test system free for you , or rent you tester . easy to use , remove rad. cap , install tester , pump bulb , find leak . good luck .
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
