Why is my AC compressor on all the time?
Old Aug 3, 2008 | 01:46 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
My car's AC compressor doesn't cycle normally anymore. It seems to be on all the time when the AC or the defroster is on. The AC still blows cool air, but it isn't cold. Such has been the case for a while, but it is only recently that the compressor has been on all the time, and it gets very hot. What could be causing this condition?
Old Aug 4, 2008 | 08:36 AM
kcb37's Avatar
Re: Why is my AC compressor on all the time?
I doubt this but maybe the clutch is siezed. I would think it would spin with the ac on or off though.
I think your problem is that you don't have enough refigerant in the system.
Thus the compressor is trying to keep up and getting hot in the process.
Hope this helps.
Old Aug 4, 2008 | 08:38 AM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
I would have to agree. Is it cycling on and off rapidly at idle?
Old Aug 4, 2008 | 02:33 PM
Saculia's Avatar
Engine: 305TPI
Actually it does not cycle at all. It stays on all the time. When I rev the engine it seems to shut off. Unless it cycles so rapidly that I can't tell when its off.
Old Aug 4, 2008 | 02:39 PM
Car: 1992 RS 6spd
It shuts off when you rev it? Then you may have just enough freon in it to keep it running while it's at idle, but when the rpm's ramp up it'll flick the low pressure shut off switch. That would be my guess.
TheExaminer
Aug 25, 2015 07:34 PM
rh76camaro
Aug 15, 2015 12:48 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
Thaney9
Aug 7, 2015 08:25 PM
