Repair / Replace AC...
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
About a year ago, I paid IceColdAir to upgrade my 91 so it could use the new cooling stuff... about $250...
After they did that, they said it still had a leak...
I asked them, worst case scenario, if everything else (compressor / heater core / etc..) had to be replaced, how much?
They told me about $1000 for parts & labor...
I just called another Ice Cold Air place today & they quoted me $1900!!!!
Can someone with some experience here let me know what these parts should cost & labor?
Thanks,
Rafael
Thanks,
Rafael
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Repair / Replace AC...
That doesn't sound very professional to me, leak testing should be the first thing done so it can be remedied before conversion and filling.. And they should be able to pinpoint exactly where the leak is..
The "new" R134a leaks much more easily than the "old" R12 as its molecules are smaller. Old style hoses may need to be replaced with special "barrier hoses".
Of course replacing everything may be expensive but I don't see why that would be necessary here.
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
dude, ur notchback is sweet. Sounds like the A/C places are giving you the runaround. you could do a number of things, but a vaccum pump (200-300 bucks) and do it yourself, its really not that hard, you could buy used parts that are still in good shape, people on the boards usually have extra stuff (i have a compressor if u need one) or you could just shop around.
Car: 1983 G20 Chevy
Transmission: 4L60
Sara Lou
Car: camaro
Transmission: auto
Axle/Gears: 700R Factory slow
Car: camaro
Transmission: auto
Thanks,
Rafael
Thanks,
Rafael
I called Advanced Auto and to get a compressor with a 2 year warranty & all new stuff, including hose / pipe kit is about $600...
I want it to work nice, so I guess might as well change everything...
Now to find a good mechanic / shop...
Raf
Raf
hey your located in tampa right there is a place here in ocala fl called are parts who could help you alot and they can make custom lines and even give you the best price on componants make and model of your car will not matter ill give you there number 352-732-0720
The drive & the how long do I wait are a problem for me...
I'm legally blind, so I need a driver... it's about a 2 hour drive each way...
Raf
Raf
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
When you switch from R12 to R134 make sure you switch all the seals...those are the most likely culprit in a leaky system after a conversion and the one thing that most shops don't chang unless they are visibly bad. Has something to do with chemical breakdown which won't be visible to the naked eye. I'd go to the dealership first and see if they'll do a leak check. They are "supposed" to go by the book price for checking that stuff so if you ask, you'll know ahead of time exactly how long it's supposed to take and how much it'll cost. that way you're not getting dicked around by a company that say "It'll take about so long..."
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
luvofjah, i have a complete a/c system that is used and worked prior to removing it for camshaft swap. the Only problem is that it needs to be coverted over to r134. Let me know if your interested.
Thanks for the offer, but I would like to spend my $$$ on new stuff...
Raf
Raf
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
