Coolant level and color issue.
Old Aug 13, 2008 | 01:29 AM
Gunman1704's Avatar
So I had a blown headgasket and fixed it and such. I flushed out the radiator and that was about it. every 2 weeks I'll check the coolant and top it of, its usually down about half an inch. Plus the water is still brown like from when it was blown. God I hope I don't have another blown headgasket. Will I just need to get a coolant flush and just keep flushing the system?
Old Aug 13, 2008 | 08:15 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: Coolant level and color issue.
Might just be gunk from an old radiator. Flush it a couple more times to make sure. Do you have any other head gasket symptoms?
Old Aug 13, 2008 | 12:59 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
You need to flush the block too. All that stuff got in the cooling system, just flushing the radiator isn't good enough, Get a outdoor hose and plug it into your upper heater hose (make sure the water flow goes into the heater core) and take off the upper radiator hose.( I also find it easier to remove the thermostat when I do this so the water can go straight through the engine) Turn the water on and flush the whole engine and cooling system.
Old Aug 14, 2008 | 08:08 PM
evans87's Avatar
Car: 1987 Iroc Convertible
Engine: Bone Stock, 66,000
Transmission: 5 speed
I just had mine flushed too and it is really rusty already. What are the symptoms of head gasket problems? Could it be that the flushing job I had done was sub par?
Old Aug 14, 2008 | 09:21 PM
Could also be that the inside of your radiator is rusty too.
Old Aug 15, 2008 | 04:34 AM
kcb37's Avatar
I would go with a reflush, taking the t-stat out, and flushing the engine, also the heater core, and the radiator.
Also check your oil to make sure it's still good if you haven't done so already.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Linson
Sep 21, 2015 01:08 PM
corey8084
Sep 17, 2015 02:56 PM
angel2794
Sep 8, 2015 06:22 PM
