Need help wiring up radiator fan, please help.
Old Aug 13, 2008 | 08:51 PM
tweakhat's Avatar
Car: 1986 Trans AM
Engine: LS1/T56
Axle/Gears: 3.83
can anyone give me a a picture or help wiring up my radiator fan? the guy i took it to wire it so when you turn the key it comes on and stays on until you shut it off then it blows a fuse, he didnt splice anything it looks like it took a wire and ran it inside the plug for the fan and ran a ground, can anyone give me a picture or tell me if i should cut off my connector and splice and wire stuff differently? it will be much appreciated, thanks alot.
Old Aug 14, 2008 | 08:24 AM
Zralou's Avatar
Re: Need help wiring up radiator fan, please help.
I just picked up a Camaro that had a nightmare fan wiring setup (guy wired the radio with the fan).
I disconnected all his handywork and tapped into the 'green' wire at the relay, then ran this to a switch and then to ground.
Now I have my fan on a manual switch when I need it, but the factory setup is still fully functional. I don't like the idea of the fan running all the time, not good for the fan motor. (BTW, my setup is a single fan).
Sara Lou
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
