Vacuum line on heater valve?
Old Aug 28, 2008 | 10:41 PM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
I am going to remove my heater core lines and the heater valve also. My question is what do I do with the vacuum line that connects to the heater valve? Do I just plug it up some how?
Old Aug 28, 2008 | 10:47 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: Vacuum line on heater valve?
Should be able to plug it...
Everyone steered me away from removing the heater valve two years ago. I was told removing that valve will cause a constant flow of coolant thru your heater core and cause it to wear out much, much faster. As you prob know there is no one that wants to replace a heater core on our vehicles, lol. PAIN IN THE CHEEKS!!!! LOL
You can easily shorten all those heater hoses. It will put your heater valve closer to the back of the passenger side valve cover instead of it's factory position right behind the A/C compressor.
See what others have to say about his mod.
Old Aug 30, 2008 | 08:46 AM
dctrumpet's Avatar
Anyone else have any other ideas!
Old Aug 30, 2008 | 09:59 AM
CaddyMan's Avatar
Car: 1990 Cadillac Fleetwood Brougham
Engine: Chevy 350 TBI with some goodies
Transmission: TH-7OO-R4, waiting for rebuild
Axle/Gears: Stock. Saving for 3.73 posi unit.
I will second the above post. Just plug it
Old Sep 10, 2008 | 11:44 PM
87IROC92RS's Avatar
Car: 87 IROC
Transmission: built 700R4
Axle/Gears: 3:27 posi
I totally agree with the others.. plug the line and shorten the hoses. I had to do that on my 92 when the entire blower assembly went out on me so I ripped it all out including the ac. I had the car down to one coolant hose and it ran hotter than hell so that was a lesson learned
Old Sep 10, 2008 | 11:58 PM
kcb37's Avatar
You should be able to plug it just fine.
You might try a local parts store, think I saw it in a Summit mag, maybe Jegs, not sure.
But at any rate you can get I believe rubber caps for the vacumm hookups.
Shouldn't be too much, just add them on next time you order something.
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
