Normal heat?
Car: 2009 Silverado 1500
Engine: 5.3 Vortec
Normal heat?
I recently replaced my heater core and Rad in my 90 GTA and I noticed tonight that under the dash on the passenger side close to the radio is very hot and no-where else under the dash is even near as hot as that area. I had the window defroster on full blast. It is the area right in-front of the heater core. Also i noticed that even with the blower off and vents closed i can still feel heat coming around my feet from the vents down to the floor. is this normal? Help greatly appreciated
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Re: Normal heat?
I've also noticed that the radio pod area gets very hot, but always thought that it was just heat from the radio. I have noticed that it gets hotter at night when the light are on. Never caused a problem so i haven't worried about it.
Car: '87 Z-28
Engine: LT1-topped 400
Re: Normal heat?
mine's always radiating heat out the vents whether it's set to hot or cold, fan on or off. really only bothers me on hot hot summer days.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Normal heat?
Well it is circulating hot coolant through there after all.
I believe that MAX A/C blocks off the heater core. NORM, Bi-level, and VENT don't. Should stay cooler around the radio area that way.
Linson
Oct 1, 2015 09:50 PM
