Fan set up from a 4th gen with 3rd gen
Old Oct 5, 2008 | 02:47 PM
amichals's Avatar
Will the 5.7 dual fan set up work and fit properly in a third gen TPI 305. Im currently in the process of buying it but need to know for sure if it will work.
Old Oct 7, 2008 | 03:15 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: Fan set up from a 4th gen with 3rd gen
Just measure it. It should be about the same size, but you'll need dual relays to get it working properly. Can be done off one, but it draws to much current.
Old Oct 7, 2008 | 05:45 PM
mesterz2889's Avatar
what he said
Old Oct 14, 2008 | 05:06 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Did you have dual fans from the factory? If so, yes.
The secret? Lots of cutting. Trim the tabs off the sides of the LS1 fan setup, and you'll need to cut the crap out of your upper radiator support. It'd probably look better with a custom piece (if you have access to a sheet metal brake, that would be KING) of aluminum or something, but it works.
Old Oct 14, 2008 | 09:27 AM
ssean92's Avatar
Car: sold
I am running the rad and fan set up on my car, but it is a lt1
Old Oct 14, 2008 | 10:59 AM
Firebat's Avatar
Running the LT1 fans/radiator here but have a LT1 also. I found it was much easier to get a LT1 radiator shroud cover, then trim it down, drill holes in it, basically retrofit it. It makes the LT1 fans stay in place much better than the thirdgen one.
Old Oct 14, 2008 | 11:04 AM
ssean92's Avatar
Car: sold
Yes sir same as me.
This is how I trimmed mine
eightsixseven
Dec 16, 2024 01:50 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
