New Jeg's electric fan control kit
Old Oct 9, 2008 | 12:44 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Here's the story:
My brand new Jeg's electric fan control kit didn't start the fan up at all, and I had to shut the engine down at 220 degrees before it overheated.
It only worked once when I first started the engine for break-in and hasn't worked since.
This is literally the 4th fan control kit I've had on the car, all different brands, and I can't seem to find one that is the least bit reliable. This one is supposed to turn the fan on at 200 degrees, off at 185 degrees when using a 195 degree T-stat.....like I have.
So I disconnected the wire from the switch and grounded the wire - I heard the relay click and the fan started right up....
-It's gotta be a bad fan switch right???
-Is there such a thing as a reiiable fan switch that will consistantly turn the fan on and off when it's supposed to??
This is really getting frustrating.....
BTW..This is a Non-ECM controlled fan system...
Old Oct 11, 2008 | 03:57 PM
Confuzed1's Avatar
Car: 83Z28 HO
Re: New Jeg's electric fan control kit
BTW, the temp gage was checked with a mechanical temp gage. The engine IS actually exceeding the fan switch setting of 200 degrees to turn the fan on. I watched engine temps exceed 230 degrees and it didn't turn on.
I let the car cool down, removed the control wire to the switch and grounded it with the key in the "run" position. Fan came on immediately.
Old Oct 11, 2008 | 04:16 PM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
get a non-contact laser thermometer
check the temp at the "sensor switch" confirm it ios seeing the requirued temp. another question is how did you seal the threads on the switch?
too much sealant can block the "grounding" required to work.
Old Oct 11, 2008 | 08:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I used the Flex-a-lite kit from Summit Racing:
http://store.summitracing.com/partde...5&autoview=sku
And I haven't had any problems with it at all - it's adjustable, can be rigged with always on and always off switches in the cabin, and it always seems to work at the temp I set it for.
Old Oct 11, 2008 | 08:51 PM
jwdomino's Avatar
Car: 82 Trans Am
Transmission: t-56
camaronewb:
problem with yours is the probe, and that there is a potential for leaks. that and temp is based off what is in your hose vs. head, or intake
Old Oct 16, 2008 | 12:40 AM
Confuzed1's Avatar
Car: 83Z28 HO
I used Locktite liquid thread sealer. I'd like to think if it didn't ground for some reason, it wouldn't have worked at all. As I said, it worked once when I initailly installed it and not since then.
camaronewbie: That's a nice kit, but more than I really need I think. I doubt I need variable fan control. I've used the probe type sensors before, and they last for a little while and fail too.
Old Oct 16, 2008 | 03:44 PM
zacks89's Avatar
Car: 89 iroc
Engine: beefed 355 for now
Transmission: 700r4 for now
i have the exact same problem. fans will not kick on at all
Old Oct 16, 2008 | 05:28 PM
Confuzed1's Avatar
Car: 83Z28 HO
Will your fan run with the ignition on when you ground the wire going to the switch?? If the fan doesn't run, then you have a bad relay, loose wire, or bad fan motor.
I'm looking at the painless adjustable fan control, part # 30112 - Anyone using that one??
I kinda like it because it uses the 12V ignition power to the adjustment box with a separate relay instead of having it all in one box, like I've gotten before..
I found the others burn up the contacts because they hook into the 10 gauge higher amperage wire and they burn out...I.E. - like the "Perma-cool" ones
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
NORTz89
May 20, 2020 03:51 PM
toronto formula
Nov 10, 2015 06:17 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
