over heating due to the radiator fan
Old Oct 18, 2008 | 04:07 PM
JMR's Avatar
JMR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
I replaced the motor because it gave out then checked the fuse which was fine so I cant figure out the problem that is causing the fan to turn on when the ignition switch is on but immediately turns off when the engine is on please help is my daily
Old Oct 19, 2008 | 09:44 AM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Re: over heating due to the radiator fan
what you got?
dual fans?
any modifications to cooling?
there is a good article in the tech section on cooling systems for both single and dual set-ups.
You say it does not turn on when you start the car? its really not supposed to unless you have it wired to run like like that.
Now, if it NEVER turns on, then you have a problem.
So, does the fan turn on when the engine reaches 220 deg F?
Old Oct 23, 2008 | 10:36 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Sounds like the previous owner has bypassed the fan relay and jumpered the fan directly to a line that is hot when the ignition is on.
I had problems with my relay. Keep burning them out. Ordered one from my local pontiac dealer.
JB.
Old Oct 24, 2008 | 02:09 PM
JMR's Avatar
JMR
you are right jim it was the relay and thx alot
Bubbajones_ya
Jul 6, 2024 08:32 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
FormulasOnly
Sep 10, 2015 09:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
