Fan Not Coming On
Old Nov 6, 2008 | 04:00 PM
cyberleader's Avatar
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
Fan Not Coming On
Hi All
I have a 91 FB and the fan is not coming on.
After idling the car for about 5 minutes, I hear a click up front and the check engine light comes on and stays on. I figure this must have something to do with the fan coming on.
The fan fuse is ok. Tried a new fan and same result.
The temperature gauge rises accordingly whilst idling. When I drive the car around the temp is at about halfway.
Is there a relay that may be the problem?
Cheers Tom
Old Nov 7, 2008 | 08:35 AM
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
Re: Fan Not Coming On
Can anyone tell me whereabouts the fan relay might be located? Is there something else I'm missing?
T
Old Nov 7, 2008 | 09:04 AM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
It is on the firewall on the drivers side..
This is a diagram from an 89 sure it is probably the same
Old Nov 7, 2008 | 09:32 AM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Check on the driver side firewall. The oval type fuse should be the fan control relay. I recently replaced mine. My fan wouldn't shut off.
Old Nov 7, 2008 | 11:07 AM
kcb37's Avatar
What engine code did you have, that may point you to your problem.
Old Nov 11, 2008 | 07:28 PM
kreature667's Avatar
I have a similar problem with my 92 rs 305. I had the fans switch changed out and the electrics checked and now (4 mo later) the fan is not turning on again. I know the fan works b/c it turns on when i put the AC on. So, any suggestions in addition to the above would be much appreciated.
Old Nov 11, 2008 | 08:17 PM
goomaan's Avatar
Car: 1987 IROC-Z
Check the switch on the block. My headers keeps melting mine. Take abou t 3-4 months then its gone
Old Nov 12, 2008 | 06:29 AM
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
Figured it out, there was an orange wire off by the battery. Fan seems to work fine. Thanks everyone, cheers Tom
eightsixseven
Dec 16, 2024 01:50 PM
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
