Radiator installation question
Old Nov 21, 2008 | 11:15 PM
rsrookie's Avatar
Car: 1992 Camaro RS t-top
Engine: 305 Jasper
I have a '92 RS with a 305 TBI.My radiator decided to take a dump the other day.It looks as if there's a split in the plastic (nylon) tank on the driver's side.Instead of doing the JB Weld thing, I'm ordering a new radiator.This is my 'newest' old car and I use it as an occasional driver.Here's my question: I want to start taking the radiator out while the new one is being shipped.Because the overnite temps are starting to dip below freezing here,can I go a day or two without the radiator?(Yes,the car will be parked!)Back in the day there was some barroom BSer that said you would run the risk of a cracked block if you didn't have your radiator hooked up in cold weather, true? I feel like a grade A a**hole for asking this question, but I'm only going to have time to work on the car a little bit each day, and I don't want to eff anything up.As always, thanks in advance for your replies!!
Old Nov 21, 2008 | 11:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Radiator installation question
It'll be fine for an indefinite length of time.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
