My Fan Doesn't Come On At All
Old Nov 29, 2008 | 01:37 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
My fan is hooked up so it's always on. Just recently I had a problem and my fan wouldn't come on at all, I replaced the relay and that was it. Now yesterday I realized it's not coming on again. What could be my problem?
1987 Iroc-Z 305 5.0 LB9
Old Nov 29, 2008 | 02:05 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Re: My Fan Doesn't Come On At All
check your wiring were the big connector is I had my fans stop working, and spend like 2 days looking over everything, and finally realized that the ground wire in the connector was fried.
Old Nov 30, 2008 | 12:30 AM
kcb37's Avatar
How did you wire it?
Little thought of mine, it is better to have it hooked up to a fan switch, these fans aren't meant to run constant, and at higher speeds don't do anything even if they are running.
Are you getting power to your switch, to the relay, thru the relay.
Do you get power to the fan?
You can jump the fan to the bat to make sure it's still working. If you have a factory or factory replacement fan, make sure you hook it up right if you jump it.
Some after market fans, you can wire them either way, just reverses direction, it will fry a factory fan.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
