cooling system troubles
Old Dec 4, 2008 | 10:31 AM
camaro3554gear's Avatar
Car: 1991 Z28 (sold), 1987 Buick GN
Engine: L98 TPI, bored 0.040 over
Transmission: TH350, 2400 stall, shift kit
Axle/Gears: 10 bolt w/eaton locker, 3.42 gears
I was just wondering if anyone has experienced these issues with their F body. During the warm months of the year my camaro runs too hot. The car will run at an average of 230 degrees and will go higher. I have replaced the radiator, water pump, several thermostats, CT sensor, fan switchs, electric fan motors, etc. I still haven't been able to find the cause of the problems. All of the factory equiptment is still intact, and the gauge is accurate according to my scanner. The car won't even cool down on the highway. One instance was when I was heading to the pocono mountains, on the turnpike the car was running good but the temp gauge was in the red zone, and you could smell the car getting hot. If someone could help I would appreciate it.
Old Dec 4, 2008 | 11:33 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: cooling system troubles
Still have the air dam?
Have you cleaned out between the ac coil and the radiator?
You can always hardwire the fan and leave it on that will help some.
Check your timing
Old Dec 4, 2008 | 11:41 AM
I just restet the timing do to some runnability issues I was having, yes the car does have the air dam in place and I have cleaned between the ac condenser and the radiator. I don't know if the timing was the factor in why it was running hot, but I just reset it a few days ago because I was having idling/ stalling problems. I guess I will have to wait until the summer to see if it cures the overheating too. Thanks for your help.
Old Dec 4, 2008 | 12:17 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
easy check and see if both fans are kicking on when hot.
if not u have a problem. troubleshoot why both fans are not comming on. should be a relay /fan issue.
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
